Lazy 440 -69
Started by Belgium R/T -68, March 29, 2008, 03:08:30 PM
Belgium R/T -68
Lined up the gears and the engine is spinning like a cat! Thanks to all.  :2thumbs:
Quote from: Rob R on April 13, 2008, 11:48:46 AM
WOW..!! now that's something you don't see every day :o  can't say that I've EVER seen that
line up the dots...6:00 and 12:00...
at least you know what's wrong now
that's something I'll never understand... I align them on that way but allwasy end turning 180º the distribuitor. that means really both should it be at 12:00, or dist to number 6 piston
73charger528cid
when trying to lign up timeing marks on a unknown engine I would go by TDC #1 cylider not distibuter location.
  just in genaral #1 in the distributer is not a fixed piont because the dist position can be adjusted altering the postion on the cap.
my self I use a degree wheel and make sure nothing is off.
but it good to hear you found your problem and its fixed and running.
