1968/9 radiator support different than '70??
Started by Death1970Proof, March 03, 2008, 07:20:33 PM
Death1970Proof
Is the radiator support on the '68/9 charger different than the '70 charger?? :shruggy:
"Remember when I said this car was death proof? Well that wasnt' a lie-this car is 100%death proof- only to get the benefit of it honey you really need to be sitting in my seat"...
I don't know about the years, but there is a different one between the different radiator sizes.  22" or 26" wide rads had a different size hole.
It's not as simple as SB/BB for determining which rad the car would get at the factory.  Air conditioning affected the standard radiator/support size too.
It's no big challenge to physically cut a larger hole for the 26" rad in a 22" core support, but the job won't look factory-done unless you swap metal from a donor car.
CornDogsCharger
the 68 and 69 are slightly different where the fenders mount.  The 70 is similar to a 69 with the exception of the three threaded studs in the center where the latch support mounts.  With a little metal work, all can be used for a replacement.  Be sure to check out 2 and 4 door coronets, satellites, etc.  They all use the same support.
Justin
"CornDog"
1966 Dodge Charger
1969 Dodge Charger (DMCL Project)
1969 Dodge Charger (WB General Lee "GL#004")
1969 Dodge Super Bee
