Heater Motor Gasket
Started by gasoline_24, March 03, 2008, 01:47:05 AM
gasoline_24
Does anyone know if they are making the rubber gasket that goes around the heater motor?  I checked RT Specialties, but nothing.  Any other suggestions?
Get a small sheet of rubber stock in the same thickness and make one?  (someone must sell that stuff right?)
Quote from: gasoline_24 on March 03, 2008, 01:47:05 AM
http://detroitmuscletechnologies.com/  shold have it no?
Same place you bought the heater box kit?
Moparrulzzz
There was not a rubber gasket for the motor in the kit I bought.
gasoline_24
There wasn't one in mine either.  However, I think you could take a flat piece of ruber and cut it to fit inside of the metal retainer.  Then cut another hole in the middle slightly smaller than the motor.  Then install the rubber gasket into the metal retainer and push the motor through the rubber gasket.  This may have been the design on the original.  Any thoughts on this?
