ALUMINUM intake STRIPPED THREADS how can they be fixed ?
Started by rav440, February 24, 2008, 06:31:18 PM
rav440
here is a description of an intake im bidding on
QuoteI just removed the carb. There is a small chip in one of the carbs stud holes. It will not affect the use if you use Edelbrock or carter carbs. If you use a Holley you may need to fix it. Also 1 of the other holley carb stud holes is missing some threads. Should work ? Just to let you know.
is there a fix for this ? retap holes ?  :shruggy: drill out for a helicoil ?  :shruggy:
thanks RANDY  :cheers:
1973 PLYMOUTH road runner GTX
mally69
rav440
Quote from: mally69 on February 24, 2008, 06:47:57 PM
what intake is it?  and how much?
its a CH4B edelbrock $150.00 with an EDELBROCK 750 carb included . the carb i have sold if i win . so that will offset the cost of the intake and repairs .
:cheers:
67_Dodge_Charger
Helicoil the intake and it will work just fine.  Costs (doing it your self) is approx. $5 to $8 for helicoil kit and your time.
Robert
doctorpimp
Quote from: 67_Dodge_Charger on February 24, 2008, 07:25:05 PM
:yesnod:
Yep, there isn't much to it.
Quote from: doctorpimp on February 24, 2008, 09:17:14 PM
:yesnod:
:iagree: an easy job to helicoil the stripped threads.
suntech
And.................with helicoil it will be BETTER than original :2thumbs:
MOPARHOUND!
Quote from: suntech on February 25, 2008, 01:27:34 PM
True, .....will be stronger with the heli-coil.
I've heard of race teams doing this to certain parts before putting them in use.
1971 Charger R/T, 440 H.P., Auto, A/C Daily Driven (till gas went nuts).  NOW IN CARS FOR SALE SECTION: http://www.dodgecharger.com/forum/index.php/topic,48709.0.html
1969 Charger 318/Auto (latest addtion): http://www.dodgecharger.com/forum/index.php/topic,31948.0.html
*Speed costs money son, how fast do you want to go, and for how long?"
*"Build the biggest engine you can afford the first time."
*"We normally wouldn't use a 383 for this build, parts and labor for a 440 cost the same."
Mfr426
rav440
suntech
That is an easy fix!!
The manifold is stripped, so you just take it to a welder, and fill in the piece missing with tig or mig. Then, grind it flat on top, redrill the hole, and use helicoil there!  :cheers:
