After undercoating is removed
Started by 71mopar383, February 16, 2008, 10:21:37 PM
71mopar383
After I spend the hours of removing all the undercoating...Should I paint it with a chassis/underhood black like from Eastwood or single stage the same color as the body(if I can ever decide what color I want).  Either way after all the heating and scraping do I need to prime it in epoxy primer? :brickwall:
Shakey
If it were me, I'd prime it and paint it the same colour as the car.
charger2fast4u
i would paint it the body color like shakey said or use POR 15 on it like i'm doing because it's cheaper
Finn
What about using spray-on bed liner? Not the prettiest thing but something different.
2002 Dodge Ram 5.9L 360
2014 Dodge Dart 2.4L
charger2fast4u
that would work not a bad idea as it should last and shouldn't have to worry about it rusting/chiping paint. also provides alittle more sound deadening i would think  i heard of people rhino linning the interior floor also.
BLAM
I would prime and paint it body color.  You can add flex agent to the paint for the underside of the car and it will make the paint bullet proof while looking great on the car!
RLTW - "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm." - George Orwell
runningman
I sprayed mine with Picklex and then painted with Zero-Rust.  I am going to end up spraying the underside with Lizard skin at some point as well.  Should last forever............well pretty much.
Finn
runningman
It's a ceramic based sound deadener.  It can be used as an under coating and can be painted over if desired.
Charger-Bodie
clean it up and paint it body color, if you decide you want undercoating later go ahead and undercoat it.
This way its protected extremely well.
