dash lights
Started by dogmank912000, February 02, 2008, 12:00:18 PM
dogmank912000
 I have a 73 charger se  dash lights won't work  where do i start?
Hemidog
FLG
Highway by the Sea
Turn the "headlight on" switch around.  It may be on "dim" or "off" position.  My old 74 Charger did the same thing (and had no dim light feature due to a bad switch) and would only come on when it "clicked".
one of the top fuses, dunno remember which one, drives the cluster lights.
do you have parking lights ?
dogmank912000
yes the parking lights work.  bulbs seem to be ok
ok, then  check one of those fuses. If you want to be sure which one drives the cluster lights, release fusebox from bulkhead and check on back... is the one linked to orange wires. is taken appart from the buss bars on fuse box
