383 build up
Started by l8rg8r, January 26, 2008, 08:57:46 PM
l8rg8r
I have a 68 roadrunner with a 71 383 bored .30 over and a 727 3.91 sure grip with 26" rear tires. I am going to do a lite build on the engine and trans here is my plan eddy torker intake 2" spacer under a carter 750 carb,mopar 284x484 cam hooker super comps with 3" flowmasters and a stage 2 shift kit. Now my question is will thiss perform well street/strip use the car has manuel brakes and stock heads I have a set of 906 heads I could install any help would be gr8
As someone with the MP 284/484 cam in a 383, I think you would like some other grinds much better.  There are a few professional builders on this site who are much better qualified than I will ever be to recommend just what that other cam should be but I can pretty safely bet they will all back me up on not using that MP cam in a 383.
daytonalo
Two words !!! Stroke it !!!
chargerman68
daytonalo
440 Source , dirt cheap !!!!
