318 exhaust question
Started by Mopared, January 19, 2008, 11:40:29 PM
Mopared
hey Guys,
On a 318 with stock manifolds what size exhaust, and mufflers would you recommend?
On a 318 does the coolant run through the heads like on a big block?
Thanks for the help.
RogerDodger
Yes the coolant runs through the heads. The outer manifold bolts (or studs) will leak coolant if removed. I ran 2-1/2" dual exhaust. All stock except headers.
dukeboy_318
Id run 2.50 true dual with either and h pipe or an x pipe and flowmaster 50series, or magnaflows, both give you a decent sound, the 50s eries are quieter inside than flowmaster's 40 series.  just my  :Twocents:
1978 Dodge Power Wagon W200 4x4- 408 stroker/4spd
1974 Dodge Dart Swinger. 440 project in the works.
