Crank Question...pretty basic
Started by zerfetzen, December 20, 2007, 02:45:30 PM
zerfetzen
I always thought our cranks turn clockwise, if you're looking at the motor from the front.  Someone said they turn counter-clockwise, and that's why the driver's side tire always picks up off the ground first.  That makes good sense, but I was pretty sure they turned clockwise.  Who's right?  And if I am, then that begs the question, why does the driver's side tire lift up if the crank rotates the opposite way?  Thanks.
Current Daily Driver: 2006 Dodge Charger RT
Current Project: 1969 Dodge Charger
Previous Cars I want back: 1974 Barracuda, 1973 Cuda
Mick70RR
The crank turns clockwise looking from the front and the engine reacts by turning counter-clockwise and lifting the driver's side up.
1970 Road Runner, 505 cid, 4 speed, GV overdrive, 3.91 gears
11.98 @ 117 on street treads
zerfetzen
See, I knew there had to be a good explanation.  Thanks.
RD
"FOR EVERY FORCE THERE IS AN EQUAL AND OPPOSITE FORCE"  newton said it first methinks. :D
zerfetzen
Sounds like I need to be sitting under an apple tree. :lol:
