numbers match?
Started by MOPARMAN25, December 16, 2007, 10:33:52 PM
MOPARMAN25
im trying to find out it this is the original engine in my car.vin#XP29H8B312617. and the block # is PT383 2415039. any info will help....thanks for all the help guys! :2thumbs:
69CoronetRT
Quote from: MOPARMAN25 on December 16, 2007, 10:33:52 PM
Look for the VIN to confirm it is the original engine. VIN stampings on 68 blocks are hit and miss. If the VIN is stamped on the block, it will be by the oil sending unit on the back of the block.
68charger383
The spot listed by 69coronetRT is the best spot, but I heard it can be found on the passenger side framerail as well.
The block casting numbers for all RB, B, and LA engines are found on the left (driver) side of the block.  In addition, on 1968 and later engines the numbers stamped on the lower rail of the engines right (passenger) side match the last 8 digits of the cars vehicle identification number.
Great site for info
http://www.mymopar.com/enginecastnumb.htm
1968 Charger 383(Sold)
2003 Dodge Viper SRT-10
In '68, the body stampings (core support, trunk rail, fender tag) won't match the VIN, starting in '69 they will.
The block stamping in the OP decode as follows:
PT383 2415039
PT= Plant Trenton  Built at the Trenton (Michigan) engine plant
383= Displacement
2415= Build date March 8, 1968
039= Sequence number, the 39th engine built that day
