help
Started by dukeboy_318, November 22, 2007, 10:26:07 AM
dukeboy_318
i bought a 8.75 rearend housing from a fellow member.  The housing has had the spring perches moved in an inch or so.  Looking to move them back to factory locations, anybody have the measurement from how far from the end of the housing to the centerline of the perches should be?  Its a 71-74 b rear housing going into a 74 charger
1978 Dodge Power Wagon W200 4x4- 408 stroker/4spd
1974 Dodge Dart Swinger. 440 project in the works.
firefighter3516
Can you us the center to center distance if so I will get under my 73 and measure the distance for you later this afternoon or I will get under there and see what other measurement I can get for you.
Joey
1998 Dakota 318
1999 2500 Cummins
1973 Charger (in bad shape but working on it)
www.myspace.com/73dodgecharger
dukeboy_318
that might work, im not sure though  thanks man
RD
dukeboy_318
right i did they just show the distance between the two, i need the distance between the perches and the backing plate
firefighter3516
I crawled under my 73 and 74 Charger with the ants and this is what I cam up with. The 73 is 4 3/4 center from the backing plates and the 74 is 4 7/8 from the backing plates and both of them the brackets are 2 1/2 wide. Hope this is what you needed.
Joey
1998 Dakota 318
1999 2500 Cummins
dukeboy_318
yep thats what i needed, thanks a lot
dukeboy_318
took a look at your chargers, btw that 74 looks to be in decent shape, 400 run??
firefighter3516
Okay if you need anything else I will get back under there just let me know. Good luck with it. I am headed back out to work on mine.
1998 Dakota 318
1999 2500 Cummins
dukeboy_318
nope thats all i needed, thanks alot and happy turkey day
