Dynamic converter
Started by Animal, November 13, 2007, 06:01:22 PM
Animal
Got a Dynamic 9 inch , 3 thousand two hundred stall converter in the charger , no problems with it , but i have to get the rpms up to around two thousand for it to moveĀ  , have got a good tranny cooler , so not to worried about O/H the box , but it's a PITA when poodling through traffic having to bring the revs up , was thinking maybe change the converter while the engine & box are out , as i've heard you can have the same stall , with maybe a tighter converter.
3:9 gears. (changing to 4:10s)
twenty six inch rear tyres.
Here's the cam specs , got no two on the keypad. ::)
Crower cam,
two94/304 adv dur
two30/two41 @ .050
.509/.530 lift
108 LSA
Thanks Adam
Hot_Rodder
Quote from: Animal on November 13, 2007, 06:01:22 PM
Crower cam,
two94/304 adv dur
two30/two41 @ .050
.509/.530 lift
108 LSA
Thanks Adam
Hmmmm, how about this:
3200 Stall
got to get it up to 2000 rpm to get it to move
3.91 gears (I'm fairly sure this is what you mean?)
26" rear tires
Cam is:
294/304 adv dur
230/241 @ .050
The rest you got.... Maybe this will make thigns somewhat easier to read......
Animal
Thanks Hot rodder. :icon_smile_big:
Sometimes you really need that number two to make any sense. :P
Adam.
That does seem awefully loose. I would send it to dynamic when you finalize your engine plans and have them adjust it for the new combo.  :Twocents:
Hot_Rodder
Quote from: Animal on November 13, 2007, 08:22:17 PM
Adam.
LOL, I hear that, ur welcome though.
Animal
Thanks Ron & Rodder , will get the vertor checked out.
Adam.
