383 build...
Started by Hot_Rodder, September 18, 2007, 10:38:45 AM
Hot_Rodder
All right, despite all the questions that I've asked, I've decided to go ahead and go with the 383 that's in the car. But, I do want to do a stroker motor. If no one has any really bad things to say about 440 Source, then I'm concidering using one of there stroker kits. I've heard some people talk about them in a not so nice way, but I'd like feedback from people who either knows of someone who's used/using there stroker kits, or are either using or used there kit's also. I'm concidering there 438 c.i.d. kit, but will concider going bigger. Now the drawback. This is a 1964 block, which I've been told that the 383 in '64, the heads that were used, had 4 valve cover hold down bolts, is this true? I ask b/c the heads on it now have 6, 4 on the bottom, and 2 on the top... The bolts are gone, and it has studs in it. Also, the intake is far from factory, being an Edelbrock TM6 with an rpm range of 3000 - 7500 rpm :o. Like I said, far from factory.... Also, with a 750 cfm Holley 3310, I tied the secondary linkage so the secondaries open the same time/amount as the primaries, and the motor seems like it can't get enough of it, and it's got a nice top end ramp speed, must be that short stroke.... Anyway, it will barely run at 1/8th throttle, extremely choppy, and at 1/4 throttle it's rough, choppy.... Half throttle it's fairly smooth, anything past that, and well.... :D. I could be wrong, but I think it's got a fairly big cam in it.... What size, I dun know :shruggy:. Also, being that it was made in '64, and this other apparent stuff was done,I don't know if it's been bored over any or not. :eek2:. And the previous owner just aint on help. I don't think he remembers how it ran, or even if it ever ran while he had it, because he said it had smooth idle, ect ect ect, and he doesn't know anything about the motor, as far as work, and he didn't know anything about the intake, until I told him. He said he bought the car to fix it up, and this is about how it was when he got it.... ::). Anyway, the 383, assuming stock bore, with a 440 Source stroker kit, would like to really move this car, '72 Charger SE with power brakes, A/C will be on the car (triple black), power steering, TTI headers and exhaust with X pipe will be used, and auto tran's (been given a rebuild price of $750 for everything including pull, rebuild, install, and warranty, a little bit better than stock). I am looking for somewhere, but no less than, 500 horse power, 500 ft. lbs. of torque. This car will be street only. I'm not certain, but the rear axle should be 3.55 SG, it is an 8 3/4" rear axle though. So, bring on the questions, and lets see what I can get myself into here, lol. I would prefer to keep it a hydraulic cam for maintenance reasons. I am planning on running a Demon carb, something like this: http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_754092_-1_10271. Obviously they offer them up to an 850 cfm, and anyone familiar with them, should know what they list, is pretty much what they flow, unlike some others.... I had a speed demon 750 on my R/T with 440 (I no longer have the car :'( ) and liked it quite a bit, no problems out of it, unlike the 3310.... I will concider aluminum heads, thought about the 440 Source heads that are supposed to be coming out, 2008 :icon_smile_blackeye:. But, if I can, I'd rather stick with the cast iron heads. The exhaust will probably be this:
headers: http://chucker54.stores.yahoo.net/man38178prim.html 3" collector
pipes: http://chucker54.stores.yahoo.net/t3sytohewimu1.html
mufflers: Probably Dynomax Ultra Flow, case design undecided right now
Tips: http://www.ttiexhaust.com/Tips.htm#slo part #TIP30-SLRED
Not a bad exhuast, right? Also, have these people: http://www.airborncoatings.com/index3.html ceramic coat the whole system. Should last for a long time that way, and perform better too. If I'm gonna sink that kind of $$$$ into the TTI stuff, it's all gonna be able to last for quite some time, this way, it should.
Anyway, bring on the q's, and I'll try and answer it all.
:cheers: :popcrn: :coolgleamA: :2thumbs: :D
Runner
you will not get 500 hp from a 750 dollar rebiuld, infact i cant imagine that being anything but a rering with no head work.  heck, even a rering with them pulling it and installing it for 750 dollars is cheap.
    ive been thinking about my next engine a little bit, it eill be biult around a 383 block sence i have a freshly bored 383 block sitting here. i have a good set of 906 heads sitting on the shelf. i will use a torker intake sence i have one but might opt for the rpm intake thats on the 383 in my satellite now. the old motor is going in my wifes pink satellite to replace the 318. what ive been thinking about is a custom piston for a .030 bored 383 and biulding the motor with a 470 crank and rod kit for a 400 block from 440 source.  this would make for a 450 ci motor.not sure on the cam, probably whatever porter racing heads sugested for a daily driven 3.23 geared 4 speed 68 satellite. crane iron adjustable rockers.   around 9.5-1 cr. id trhink it would be simple and fun.   if this even happens it would be a couple years down the road.
histoy
I believe that '63 was the last year that 4 bolts were used to secure the valve covers on big block engines.
Hot_Rodder
The guy I talked to at the transmission shop that I talked to, said that the transmission should be able to handle that kind of power, so, it's there warranty if it breaks up..... Also, obviously you couldn't mean build a motor for $750, stroker kit alone through 440 Source is around $1650 fully balanced and all. Then there's the rest of the stuff. BTW, I've already got a Milodon street/strip low profile oil pan, and a 1/2" pickup, next will be the high volume oil pump and hardened shaft and such.
Runner
  yup i screwed up reading your post.   sorry....
Hot_Rodder
Quote from: Runner on September 19, 2007, 04:10:31 PM
It's cool. $750 I figure would rebuild the 383, but would be reusing a lot of stuff. 500/500 power would be very hard, if not impossible, to reach for that amount.
Hot_Rodder
Well, thanks to a friend, I've made up my mind, and get a crate motor. No guess work, ect. Here's the link, what you all think?
http://speedomotive.com/ps-225-62-mopar-383cid-to-430cid-street-master-stroker-engine.aspx
Hot_Rodder
Quote from: histoy on September 18, 2007, 07:37:46 PM
66 as far I know ( I can be wrong thought )
Hot_Rodder
How about I pull the covers, and see what the casting # is? I got a few minutes today, so I guess I'll check 'em out and see what's what. :popcrn:
Quote from: Hot_Rodder on September 24, 2007, 10:01:54 AM
here is a list I saved from the old board, but I think is not accurate since states 452 heads for 76 and laters engines... my car is 74 with 452s and almost all 73 400s I have found down here are with 452 too
chargerman68
get a hold of firefighter3931 he has alot of knowledge about motors great help with mine
Hot_Rodder
Firefighter knows his stuff, and so does Chryco. I pulled the valve cover off, and yes, it really didn't want to come off at all, but I did get the cover off the driver side... Anyway, I can't see any casting numbers, but here's two pic's of what it looks like right now.... I'm going back out there to pull the rockers off as soon as I get these loaded up.
wooops, those rockers have missed the spacers between them
chargerman68
supserdave
$3695 for the short block isn't a bad price. Can you pick the cam to use in it?
Hot_Rodder
As for the crate motor, I plan on just buying the "turn key motor" so that way there's no other work needing to be done other than put it in, make some connections, ect... Besides, it's got the 500/500 mark that I want, infact 500/530... Good enough, so why mess with it? Besides, I'm not building a race car, just a nice street cruiser, with an occasional show off :D. Anyway, here's some pic's after I removed the rocker assembly. Also, this is the first time that I've pulled anything on this motor off, so, the rocker assembly isn't my fault, but does add to the potential that the heads aint factory. :shruggy: The number looks like a 516.
73.5 cc head, from '64 until sometime by the list above, with a 2.08 intake valve and a 1.60 exhuast valve. So.... Maybe these are the original heads, but someone had to have messed with it some point in time.
TUFCAT
I noticed this engine has the 516 heads. Many people have gone on record as saying the 915 head (67 440) is the best closed chamber head from this era. My 1967 383HP block has the 516 heads and I was going to use them, but have the exhaust vales enlarged. Is there any reason for me to consider 915 heads instead of the 516's I already have?
71 B5383
I think the difference,besides the valve sizes, is going to be in the port itself.It(915's) may flow a little more but I think the 516's exhaust opened up to the 1.74 will be just fine for you.Have them blend into the port a little bit when putting the bigger valve in.You are not building an all out race car as you said,so you'll not notice the slight difference.As for NACHO and his heads,the 452's were for trucks and motorhomes75-76 and up I believe,that is always where I got mine off of.The 346's ran from 70 or 71 til 73 or 74.All open chamber low compression smog heads!Boat anchors unless your building a stroker or changing pistons. :Twocents:
Should've Kept My '66,That Was 6 Cars Ago
Currently-
  Rust Free 71(383,GB5,HardTop) Charger
  Soon To Be An FJ5 Stock 69 440 Magnum'd 3.55'd
   Correct "LOOKING" Super Wanna Bee
        (by the way,gotta 71 Super Bee hood 4 sale?)
           some cash and my 72 Power Bulge hood?
aifilaw
have them size check it and tell you how far into the head they are going to drill out the exhaust valves... my last set hit the water jacket... not because the machine shop were idiots... but because they didn't check first and the water jackets had rusted deeper... thusly they barely hit the jacket when they opened up the valves.
'72 B5 Metallic Blue Hardtop
TUFCAT
I would probably only go up to the 1968 exhaust valve size.  Since I won't be running headers, it won't make much sense to go bigger thant that right?
RD
Quote from: 71 B5383 on September 29, 2007, 08:49:15 AM
smog heads? ha... when fully ported as done by mopar muscle and compared against the 906, 452, and 915 fully ported, the 346 outflowed all of them.   there is no such thing as a smog bb head.  346's came w/semi-hardened valve seats to handle the unleaded fuel, but that is the only difference between them and about any other open chambered head in stock form. (there is a website that shows the differences with charts, I am at work, hence I do not have the link, maybe someone can help).
452's were found on all bb motors from 75 on, unless it was a motorhome or industrial (213) motor.  And in some cases on industrials too, it just mattered what the factory had on hand at the time.
if you claim 346's as boat anchors, then I guess 906's and 452's are boat anchors also.
I'm still acclaiming, as far I know my car came with 452 heads and is 74... I have three pairs of 452s, one of them the original from factory ones
chargerman68
Quote from: Nacho-RT74 on September 24, 2007, 10:27:13 AM
[my car is 74 with 452s and almost all 73 400s I have found down here are with 452 too
The "correct" 73-74 casting is a 346. If yours has 452 castings then they're not original to that engine. ;)
As for the 516 heads ; they are very poor flowing, particularly on the exhaust side. The only reason i see to use them would be to bump up the compression on a late model smog motor which typically were 8:1 with the open chamber heads. Even at that i wouldn't be looking for any big power gains with the 516's....they just don't flow very well without extensive porting.  :Twocents:
