summit exhaust
Started by 1BAD68, September 14, 2007, 01:29:42 PM
1BAD68
I just finished installing the el-cheapo 2 1/2" dual exhaust kit on my 68 Charger, $216.00 to my door.
Its not bad, it went in fairly easy and I didn't have to buy anything extra, comes with tons of clamps and hangers. The only problem I had was fitting the pipes that go over the axle. I have a custom shock mount so the clearence was too tight for the stock bends (had to cut and weld to fit) but overall, if you're on a budget this is a decent kit. It sounds good too, I took a video of the first fire up but dont know how to post it on here, its too big.
chargerman68
would love too hear cause im just about to order the same for my 68 charger
srpntlair1
I bought the kit for my 73, had the shop weld everything instead of clamps, also like most summit items, it is name stuff with summit markings and the mufflers are identical to flo-pro's. it is awesome and no problems anywhere...bolted right in for the money you can't beat it
Mean 318
when I put mine on I had to add a hanger to make it stay in place. Outside of that it wasnt too bad.I too had someone weld it up. I like it, but oe day will be changing the mufflers. I will also be adding cut outs to it.
Mine has stock HP manifolds... for now and mine is the 3" kit.
If anyone wants th hear it, this is my video
http://www.youtube.com/watch?v=1iQ3MOXFhqo
