Gary Dourdan's 1968 Charger on TMZ
Started by Sinister68, September 11, 2007, 10:05:00 PM
Rolling_Thunder
Let me draw the little Diagram up and i'll send it to both of ya.
TUFCAT
Thanks for the help Thunder!!  Maybe you should post a thread on it?  You are the man.  :yesnod: :yesnod: :yesnod:
68charger383
Hey Thunder,
I'll take a diagram as well if your are not going to post it.
Thanks in advance.
1968 Charger 383(Sold)
2003 Dodge Viper SRT-10
suntech
dkn1997
I agree, I now like CSI a little better than before.  sweet sound.
RECHRGED
Dave22443
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
- Abraham Lincoln
Brock Samson
Rolling_Thunder
Its easy guys - on your "body wiring" for your front light harness, you have a 6 pin connector numbered termincal 1-6...    terminal #2 has a black and yellow wire coming out of it. Simply link this wire to the dark green wire in terminal #5. Terminal #5 supplies constant power to your side markers. The black and yellow wire only carries power when your headlight switch is set to "running lights". Make sure to swap the wires on the HEADLIGHT side of the harness (The wires that connect to the headlights, not the bulkhead)
Simply crimp a new connector on both wires and slide them into the #5 terminal. on a 1969 I believe There is no wire in terminal #5 presently, however if there is a dark green wire coming from the bulkhead to the 6 pin connector, you only need to swap the wire from terminal #2 to Terminal #5.
TUFCAT
Wow, That's SLICK  ;)....very well done diagram - -  THANKS!!!!  :2thumbs:
Rolling_Thunder
Supercharged Riot
