wiring problems
Started by will 73se, August 25, 2007, 03:47:57 PM
will 73se
how tuff is it to install new wiring harness and do i have to rewire all of car?
what harness ?
anyway probably is tuff but a pleasure. If we talk about underdash, better do it with dash farme out of car and then mount harness on dash. Reassembly as complete assembly.
Hot_Rodder
Do you have to rewire the whole car, don't know, depends on the condition of the wiring. Is it a good idea to rewire the whole thing, IMO yes, do you have to, if the wiring is good, then no. Otherwise.... But as Nacho said, it depends on which harness, there are several different harnesses.... Right now I'm in the process of replacing my engine/AC/tran's harnesses that I got through Evans. :cheers:
Sorry about that post that I misplaced that was below.... I've moved it to it's correct place.
