Motor Mounts
Started by 69chargerdad, September 23, 2005, 04:18:51 PM
69chargerdad
We are looking to buy new motor mounts for my 440 and have heard of the problems of stock mounts. However we did find Magmount hd motor mounts, that use a bolt through design. Has anyone here used these? do they cause the car to ride rough(vibration wise) because im looking for something durable, but not solid. We will also have an engine torque strap. Thank you
        Marcus
cudaken
 Marcus, best idae Ron (firefighter) ever gave me is what I have done. Had my cheap $10.00 drilled then installed 2 grade 8 bolts installed. Think it cost me a toatl of $20.00 not counting the mounts.
I will added a strap, and then some with 789 Foot pounds, but the trick Ron gave will be fine for break in. Then on goes the Super Charger. ;D
                                         Cuda Ken
I am back
The mod Ken describes has been used many times and works very well. There is a company called "mity mounts" that does basicly the same thing as the double bolt mod descibed above. The idea is to just snug up the bolts enough to keep the buscuit from seperating while not compressing the rubber too hard so that vibration is transmitted through the chassis.....it works !
