Booster goes WOOOSHHHH!!
Started by T16, August 16, 2007, 02:39:10 PM
T16
When i press the brakepedal the booster goes.. WOOOOOOSHHHHH!!
Is this normal/ok..?
68chrgrwife
MOPAR OR NO CAR BABY!
LOVING MY HUBBY: CHARGERMAN68
1973 DODGE CHALLENGER: SOLD :(
1968 DODGE CHARGER RT CLONE (OK, SO IT'S HUBBY'S BUT IT'S MINE TOO, RIGHT?)
2008 DODGE CHARGER
2005 DODGE MAGNUM R/T (YES IT'S GOTTA HEMI)!
Mine did since I got. Recently rebuilt it and still does it but less than before... anyway never have had a fail because that.
T16
Ok.. brakes are good.. so i guess its ok.
Anyway.. got weak vaccum reading (http://www.dodgecharger.com/forum/index.php/topic,32519.0.html) and though this maybe was the problem.. gonna try to block all vacuum sources of tomorrow, and se if it´s getting better
Thanks  :cheers:
OldGuy
Sounds like there is a leak in the booster somewhere.  However, if there is a booster leak the brakes gradually fade and the pedal goes to the floor.
"I can tell by your sarcastic undertones, rude comments and total lack of common decency, that you and I could be best friends".
THE COLONEL
Quote from: OldGuy on August 16, 2007, 05:38:31 PM
That's what happened to me this past weekend. :rotz:
"THE COLONEL....DIFFERENT RANK...SAME ATTITUDE"
no, I have experienced that "woooshhh" stuff. Is pretty more that when you press pedal then being you are enlarging the room on this side of vacuum chamber on booster, then needs to fill that enlarged volume with the air enterng from somewhere, pretty sure throuth rear "seal" of booster piston.
is_it_EVER_done?
Assuming you don't have a leak in the booster somewhere, the Whoosh is caused from a improperly adjusted M/C pushrod (from the booster into the M/C). Remove the master (you don't have to remove the brake lines), and adjust the pushrod to make it longer.
Charger_Fan
Did it just start making the whoosh noise recently? If so, I'm betting the booster diaphragm has developed a crack or hole in it, causing a vacuum leak. I just went through this very thing on my F250...HUGE hole in the diphragm. I replaced it with a new one & all's well with the world again. :icon_smile_cool: :lol:
