F70x14 Tires
Started by zerfetzen, August 15, 2007, 07:30:27 PM
zerfetzen
What does F70x14 mean?  I'm sure these are for 14 inch wheels, so the question is: what does F70 mean? 7 inches wide?  Any takers?
Current Daily Driver: 2006 Dodge Charger RT
Current Project: 1969 Dodge Charger
Previous Cars I want back: 1974 Barracuda, 1973 Cuda
resq302
I could be wrong, but I think the F stands for how wide the tire is and the 70 is how tall it is.
Brian
The letter is more like a load rating and the 70 is the aspect ratio meaning the sidewalls are 70% high as they are wide in this case.
zerfetzen
Thanks, I never knew that  :2thumbs:
OldGuy
Actually, the alpha letters determined the diameter of the tires in comparision with the width.  The nominclature was for bias ply tires.  There were four (4) letter ranges in the 60 and 70 series tires - E,F,G and H. The diameter of the tire increased as the letters went up (side wall height) thus reducing the revolutions per mile.   However, the wider the tires were (60 Series vs 70 Series) with the same alpha lettering, the smaller in diameter due to the increase in width.  The 60 Series were wider than the 70 Series (sorry, I don't know what the difference in width between the two series was).  So, if you wanted a wider tire - (60 Series) but the same diameter as a 70 Series tire for mileage, you would have to go up in the Alpha lettering in the 60 series (increase side wall height) - i.e. H60x14 was about the same diameter as a F70x14.  The 78 Series had a greater diameter range (A through J) but not as wide - Mom & Pop tires :icon_smile_big:
example:
Tire Size          Diameter          Rev/Mile
E70x14            25.8               783
E60x14            24.8               814
F70x14            26.2               769
F60x14            25.3               798
G70x14           26.8               752
G60x14           25.8               782
H70x14           27.5               733
H60x14           26.4               764
I ran G70x14's on my 1968 Charger back in the day (1969-1971)
A good comparison chart can be found at  http://www.turbinecar.com/tires.htm
"I can tell by your sarcastic undertones, rude comments and total lack of common decency, that you and I could be best friends".
zerfetzen
Thanks OldGuy, great info!  :cheers:
