1970 Charger decal placement questions
Started by Rolling_Thunder, August 10, 2007, 05:32:40 PM
Rolling_Thunder
Need to know where the following decals go on a 1970 Dodge Charger R/T
Manually opening headlight door: yellow sticker approx 1" x 3"
"jacking instructions for sure grip differential"
"Use only 180* thermostat use mopar antifreeze..."
"air conditioning max charge 1.19kg..."
"Caution follow jacking instructions"
"manufacturer certifies to dealer this vehicle upon completion of...."
"Warning disconnect regulator before trouble shooting" paper tag
pics would help immensely
1970 Charger 500
I have a '70 500
the antifreeze decal is on the left because of my AC
it would bo on the right if no AC
My jack decal was in that spot originally
There are some other decals here that you did not ask about, but took pics anyways
1970 Charger 500
hemi-hampton
My research says the Air Filter decal goes on pass side of Air Cleaner, not front. Headlight decal & Antifreeze I've seen vary on unrestored original cars. :Twocents: :shruggy: LEON.
