Carter AVS 4966?
Started by max, August 06, 2007, 05:16:02 PM
max
i know the Carter 4966 is the # for a 1971 440 but is it an HP carb # and what is the CFM listed for it?
histoy
My 1972 Chilton's manual shows that the 4966S has a primary throttle bore of 1 7/16".   The 4968S listed for a 1971 engine has a primary throttle bore of 1 11/16", so that may be the HP carb.   The manual doesn't show the cfm rating for either one.  Hope this helps...Brian
idahogrumpy
If it is a AVS it is probably close to a 600-625 cfm rating. If it is a Thermoquad they had a 750 and 850 cfm rating.          Grumpy
Too much to say
Too much to do
Too tired to get it done
Too stubborn to give up
GRUMPY
Modified 73 440 Charger, 03 Intrepid SXT, 02 Neon and 2001 Ram 1500 .
rt green
third string oil changer
4966 C-4-AVS 71/O 440 A-120 A/T
A120 is the standard performance 440, A134 is the HP.
Carter never published the cfm ratings for OEM carbs so it's anybody's guess.
But they were all 600-625, correct?
I always get flak when I say this but the literature handed out in the old Performance Clinics stated some pretty low cfm numbers for the AVS, my memory says 585 for the small version and 635 for the large. Of course, that literature is long gone.
max
thanks everyone for the infomation. i wasn't sure if there were any links to the cfm ratings or not. i know over the years i have read alot of strange things about the cfm of the carter carbs but none of it was truely verified, so it was only a guess in my eyes.
oldkimmer
4966s= 19*71 440 auto low performance    approx 650 cfm..............kim........
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
