1/4s different for 71-74???
Started by no318, July 24, 2007, 10:15:58 AM
no318
Are they all the same or not?  What is the way to tell the difference between years?  I was thinking that 73-4 are the same.  Thanks.
71/72 are the same except for the sidemarkers
73/74 are exactly the same
However, 71/72 are not the same than 73/74.
differences:
-Body line on rear end, 71/72 is straight, 73/74 does have a "flip up".
-because bodyline, curvature on that area is not the same wha in fact makes quarter extension don't match between those years
-quarter is taller in quarter window opening, around 1.5", so upper body line doesn't match there either.
-Of course C pillar completelly different
Maybe and JUST maybe lower body lines matches same as wheel opening, not sure how much or if need some hard job to make them match. NHCharger knows it better since he used 73/74 quarter patches to fit on its blue 72
no318
Thanks man.  I found a set of lower partials, which will work to patch what I need.  I don't know about the wheel openings.
