Cam select
Started by orange68, July 13, 2007, 12:47:42 PM
orange68
I just bought a pair of eddy heads for my 440", and worked fine for ap. 50 miles, then the cam gear went bad and bent some valves. The "pin" in the cam are worn out so I need a new cam and like to have some suggestions of choice. Stock 440", flat top pistons, eddy 84cc heads, Dynamic 11" converter (app. 2500rpm stall).
Quote from: orange68 on July 13, 2007, 12:47:42 PM
I just bought a pair of eddy heads for my 440", and worked fine for ap. 50 miles, then the cam gear went bad and bent some valves. The "pin" in the cam are worn out so I need a new cam and like to have some suggestions of choise. Stock 440", flat top pistons, eddy 84cc heads, Dynamic 11" converter (app. 2500rpm stall).
Engle k56 or k58 camshaft will suit your needs.
