Lowering the front end
Started by Harlow, July 12, 2007, 07:18:11 PM
Harlow
Hey guys. I'd like to drop the front end a little (no more than an inch). Heres how it sits now. I would like to do it via the torsion bars. Does anyone have advice when doing this? If I drop it an inch or so will it screw with the alignment?
Charger-Bodie
an inch sholdnt hurt but id get an alignment when youre done. but beware that they ussually settle alittle more so drive it alittle and be sure its where you want it before spending the cash on an alignment.
Before you touch the adjuster bolts, spray the threads & threaded blocks with penetrating oil a bunch of times & give it time to soak.  Those things break off when they get too rusty.
And I always do T-bar adjustments with the car jacked up in front (not much weight on the wheels), even if you're just trying to lower the car.
put a tape measure across the tires front & rearĀ  , you need 1/16 - 1/8 " toe in
Steve P.
are you sure that you are going to keep the present tires or at least the same tire size on it?? If so go ahead and make the changes you want. It's a good idea to have it aligned soon after your final adjustments. A (GOOD) alignment mechanic will check your ground to frame hight as a rule. Just make sure you mention to them that you have made some height adjustments so they check it for sure.
Steve P.
Holiday, Florida
