what primer do i use
Started by skeets 66, June 27, 2007, 09:07:41 AM
skeets 66
Waht prime should i use   ..Body work is all done,what prime should I use before car is painted ??
mopar_madman
epoxy prime for bare metal and high build primer for block sanding. You can seal everything when done before painting , I would use all the same brand and system (all dupont, all PPG ect) to keep compatability issues down. What type of paint are you using? urethane, enamel? base clear single stage? are you painting it or a shop? More info you give we can give  more advice.
1973 Dodge Charger
1968 Plymouth Road Runner
1971 Dodge Dart Swinger
Silver R/T
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
