No Brake Lights - 70 Charger
Started by TripleBlackGator, June 27, 2007, 09:00:07 AM
TripleBlackGator
Here's what I have checked. Turn signals work both left and right, front and back. Flashers work front and back. All fuses "look" good. All bulbs in rear (6 total- 4 1157 and 2 1156) are good. All 6 should come on when hitting the brakes. Right? I also checked plunger at pedal. It is moving and removed connection there and found NO corrosion. Any idea what I may be missing. I am postive I have a good ground. Any simple tests that can help determine what's up?
Malicious, vindictive, spiteful, cynical, pessimistic, sarcastic, & antagonistic. And those are my good traits!
no... just 1157 should start on with brakes... the inner ones  are part of parking/positioning lights.
1156 are not the right ones for red lenses... if you stay with those will melt the lense because as far I know they sit closer to lense on 69-70s on the inner sockets. Right now dunno remember the right bulb number, but has been posted... to rest of info, will analize and post later. have to leave now
Plumcrazy
The inner bulbs in the taillights should be a #67 or #97.   They do not come on with the brake lights.
There are two wires at the brake light switch.  One has power all the time, the other only when the brake pedal is pressed.
If the brake switch checks out okay, you probably need a turn signal switch.
Pink wire up to brake pedal switch is the same source than the positive to dome light, so if you have dome light then you should have power there unless wire up to pedal brake switch is damaged.
Place a jumper between pink and white wires arriving up brake pedal switch. If pink wire is powered and brakes come on, then brake pedal switch is damaged.
If doesn't come on, with jumper still on place check for white wire power under column, on turning switch harness. If you have power there, and no power on brown and dark green wires ( outputs to rear lights ) then turning switch is damaged or its harness
TripleBlackGator
Ok here's the update. I am assuming that the brake lights and the stop lights share the same fuse. Am I right? Now I pulled the white and pink wires off the brake pedal switch and used a "jumper" betwen the two. Doing so I still have no brake lights. I take it then that you are saying it could be a bad turn signal switch or turn signal harness. If so, how do you access the harness. I never had the column apart and don't really want to but I need this fixed ASAP. Any help is appreciated. ALSO: What is the number of the inner bulb? The one with one contact and one filiment. The "running" light. What came out (from the 70's) reads 1095 but can't find that number at the local Advance Auto store.
need to remove the wheel and you will get acces to the turning switch.
stop lights and brake lights ? depends what you mean with one or another... I understand both are the same just different called.
Brakes light share same fuse than dome light.
Quote from: TripleBlackGator on June 29, 2007, 10:30:39 AM
Plumcrazy posted the replacement #'s above
TripleBlackGator
Quote from: Just 6T9_CHGR.... on June 30, 2007, 05:33:57 AM
ALSO: What is the number of the inner bulb? The one with one contact and one filament. The "running" light. What came out (from the 70's) reads 1095 but can't find that number at the local Advance Auto store.
Got it Just 6T9_CHGR. My local Advance Auto is sold out of 1157's and 67's and 97's. What's up with that? I'll be going to Pep Boys tonight. Anyways.....I was looking into the brake light problem again this morning. There is power at the pink wire. I disconnected the pink and white wire from the brake pedal switch and ran a wire from one connector to the other. I still do not have brake lights? I am believing now that there is a problem with the wiring harness (white wire) for the rear of the car. I am not sure when I lost the brake lights. Does anyone know the route the harness takes from the dash to the taillights? I installed new carpet a while back. Could the wires have been damaged during the carpet install. I don't remember there being a wiring harness to deal with when I put in the carpet. All ideas are appreciated.
Charger_Fan
They were sold out of 1157's?? That's sad. :rotz: I could see being out of 67's or 97's, but 1157's? ::) Yeesh.
Anyway...It's been a while, but I'm 98% sure the wires heading to the taillights are routed under the door sill. If you take off the aluminum door sill cover & push the carpet back, you'll see a rounded piece of sheet metal spot welded to the body of the car, running the length of the door opening. Your wires are in there.
You can fish them outta there for testing.
Back when mine was used for daily driver status, I had to replace my t/s switch because of no brake lights too. I don't remember now if the turn signals worked at the time, or not. Replacing the switch isn't too tough, just a little time consuming.
TripleBlackGator
Quote from: CHARGER_FAN on June 30, 2007, 04:47:47 PM
If I have power going to the brake pedal switch then I would assume my T/S switch is ok and that my problem lies in the white wire going back to the tailights. Is there a "sub" harness further back that goes from the white wire to the three wires on each side for the tail lights? I should be able to do a continuity test on the white wire once I find the other end.
Plumcrazy
Quote from: TripleBlackGator on June 30, 2007, 08:26:57 PM
The brake lights and the turn signals use the same wire and the same bulbs and the same filiments in those bulbs.  If the turn signals and flashers at the rear of the car work then you do not have a problem with the wiring back to them.
If you have power in the white wire at the turn signal switch connector when you press on the brake pedal, replace the turn signal switch.
TripleBlackGator
I have power going to the white wire that is connected to the brake pedal switch. I suppose this is NOT the same as the white wire from the turn signal switch. Is it? Also, if there is steady power going to the brake pedal switch via the pink wire even without the pedal being depressed then what illuminates the second filament in the 1157's?
1971SE440
I had the same problem with 1971 with no brake lights. I went through everything and could not find anything wrong...still no brake lights. I took it to a shop and my buddy told me it was the turn signal switch in the steering column. I thought he was nuts...but I ordered a new switch complete w/harness from Year One $102 and he installed it and I now have brake lights. Go figure.
Once and again, power route to brakes is:
pink wire up brake pedal switch allways powered
then becomes on white wire powered when brakes are pressed. THIS WIRE IS THE SAME ARRIVING TO TURNING SWITCH
with turning switch and hazzards off, then white wire feeds normally the brown and dark green wires ( rear ligths ). So is linked for a while everything on turning switch is off. If turning switch is good you must have power on dark green and brown wires with powered white wire, jumped with pink wire or plugged and brakes pressed at brakes pedal switch.
Quote from: TripleBlackGator on June 30, 2007, 10:42:42 PM
First filament is feeded by parking position net with black wire, same as sidemarkers... second and brighter filament for brown or dark green ( depends of side ) what are brakes, hazzards and turning
Plumcrazy
Quote from: 1971SE440 on June 30, 2007, 11:30:02 PM
It makes perfect sense.  What is confusing everybody is the fact that the brakes lights and the turn signals share the same filiments in the same bulbs at the rear of the car.  If they just ran a wire from the brake switch to those rear bulbs, as soon as you stepped on the brake you would not have a rear turn signal anymore.
TripleBlackGator
What was confusing me was the signal flow. I thought it was from the column to the brake switch to the rear lights. My understanding now is that the signal goes from the brake switch to the column and then the rear lights. Am I finally understanding this? If so, then I will look for a switch and harness at Carlisle. Now....does anyone have pictures or detailed instructions of removal of steering wheel (woodgrain & big black center horn) and removal of switch and harness. I do have a puller and could probably figure it out as I go but if I can avoid a mistake or learn a shortcut I'm all for that. Thanks everyone!
When you turn on one side, that side changes the input source from the wire coming from turning flasher ( is the red one on turning switch harness ), for a while the non turning side keeps the input source coming from brakes ( white wire ) to keep brakes working to that side.
On hazzards, the brakes white wire input is completelly cut to then make the source coming from pink wire ( on turning switch harness ) what is the hazzard flasher source to all 4 corners.
We have then 3 constant inputs: brake pedal switch and hazzard flasher with power allways, and turning flasher just with ignition key on RUN or ACC.
and 4 outputs one to each corner, being just rears discriminated by brakes input.
the extra wire ( black ) is horn, and drives ground.
While you're at Carlisle pick up a FSM.... all the instruction you need is in there
TripleBlackGator
Quote from: Just 6T9_CHGR.... on July 01, 2007, 03:28:13 PM
Forgot I had one. Thanks!  ;)
killer8man
I've got the same problem in my '71. I found this post and it sounds like you've got the exact same problem I do. So...I ordered the switch and harness from Year One and I took the steering wheel off and the big bolt in the middle of the steering column and that's as far as I got. How do I take the rest of the stuff off so I can access the switch? Thanks for all of your help ahead of time.
Cheers,
Adam
P.S. Happy Independence Day to all of our veterans and active duty military from an active duty Navy helo pilot.
TripleBlackGator
My Factory Service Manual  (The BIG THICK PURPLE one. Ha Ha) isn't very clear on how to remove the switch and associated harness. It also doesn't show how to remove the big black horn button. Anyone know the RIGHT way to remove the horn button WITHOUT damaging anything? Also, if the problem lies in the switch can just the switch be purchased or is the harness hard wired to the switch? How much disassembly is involved in getting switch and the harness out? Sorry about all the questions but the steering column is very foreign to me.
killer8man
My '71 has a '69? steering wheel with  the big black horn button. I just pulled it off with my hands. Came right off with a little tug. I can't imagine doing any damage pulling it off that way.
