Lowering?
Started by TBCharger, June 23, 2007, 11:58:31 PM
TBCharger
OK, Im kinda ignorant when it comes to stuff like this, and I havent had much experience with older cars like these, but how do you lower a car that doesn't have springs, like my 72 charger. Is it with the shocks? Im not worried about the rear suspension, I have air shocks and I dont wante it lower anyways, just the front. Thanks. :scratchchin:
Charger1973
You can adjust the torsion bars with the adjuster bolt, but you need to be careful not to get it too low or your suspension will bottom out on itself.  Also you will need a front end alignment if you change the height.
Charger1973
Another thing to remember is that when you lower it you release some of the tension on the bars and the ride will lose some of its stiffness so the front end will seem bouncier the lower it is.
TBCharger
Charger1973
Hey no problem.  If you go to lower it, make sure you are adjusting the right bolt because if you have never done it before its a little tricky to tell which one it is.  Id post a pic if I had one but I dont right now.  If you need a pic I can take one but it wont be tonight.   ;)
TBCharger
Dont go take a pic just for me, Ill figure it out. Ill probably try it tomorrow or sometime this week. Also getting some Cragars. :yesnod:
Thanks again.
Mo Power
Hey where is this bolt located on a 73 Charger not a bad idea to lower them I dont got any knowledge on front ends so if you could show me a picture that would be helpful.
1973 Charger SE
1972 Roadrunner-1 of 34 power sunroofs
          Crazy colors, Wacky decals, and Massive engines
                      That's what Mopars alll about
is the 13/16 bolt located in LCA... in fact that's the only bolt around
Charger1973
Quote from: Nacho-RT74 on June 27, 2007, 11:12:27 PM
True.  The reason I say it is confusing is that when you look for it, if you dont know what you are looking for, its not what you would expect to be looking for.  Heres a picture.  Sorry I dont remember whos picture this was and I know its not a 3rd gen but its in the same place.
Mo Power
Thanks I going to give it a shot
1973 Charger SE
hemihead
What they forgot to tell you is anytime you mess with the front end you should have an alignment done.
Lots of people talkin' , few of them know
Soul of a woman was created below
  Led Zeppelin
Charger1973
Quote from: Charger1973 on June 24, 2007, 12:08:38 AM
