which electric fuel pump?
Started by 69Bee, June 17, 2007, 06:04:12 PM
69Bee
hey guys, i need input on which electric fuel pump setup i should go with?   should i get a regulator also?  the car will be mostly street with some strip use.  the link to my setup is here......    http://www.dodgecharger.com/forum/index.php/topic,28996.msg325371.html#msg325371
i am using a might demon 850 carb.   thanks
Josh, go with the Mallory 140 gph pump & regulator and run a return line to the tank. The Mallory pumps are efficient and quiet.....i like them. When i upgrade to an electric it will be a Mallory....no question !  ;)
aifilaw
one more vote for the mallory. Got one that's been running for 3 years in atrocious conditions flawlessly
'72 B5 Metallic Blue Hardtop
69Bee
thanks guy, got one ordered.... how should i go about setting up the return line?
Quote from: 69Bee on June 20, 2007, 10:41:59 PM
Good call on the pump....you will be happy !  :2thumbs:
You can run the return line paralell to the supply line and plumb it back through the fuel sending unit or you could weld a bung up on the filler neck just above the tank and return it through there. If you're using a 3/8in supply line then use a 3/8in return line. Mak sure you ordered a 3 port regulator which will have provisions for a return line.  ;)
As for the return line ; braided rubber, aluminum or steel will all work fine....avoid using plain rubber as it can be damaged from road debris and start leaking fuel... causing a fire.  :Twocents:
69Bee
the pump came with the regulator as a kit, its the return line type too. thanks for all the help !
Charger-Bodie
what would happen if you dont use the return line im just curious how much will it hurt?
if the pump[ cannot bypass internally you have to run a return line or you will burn the pump out
