help wont start
Started by chargerman68, June 16, 2007, 01:43:15 AM
supserdave
Yellow port is usually used for power brakes to the booster....
EffinDuff
I have the yellow port connected to the PCV valve and on the back of my strip dominator intake there is a port that is connected to the power brakes.  Is this wrong?  :shruggy:
UFO
EffinDuff- your hookup is right.
chargerman68
hey got spark but now there is fuel pouring out of the blk circle on the carb after acouple of cranks....any ideas
supserdave
Float is either stuck or set to high..........
chargerman68
how to adjust.....
brand new out of the box carb,didnt know i had to adjust anything.
Charger-Bodie
prob. stuck then tap lightly by the fuel inlet , try again.
chargerman68
chargerman68
update carb keeps catching on fire.......
supserdave
What Brian said........I never played with an Eddy carb, do you have the instruction manual, or get on there website and check.
chargerman68
so now it is spitting gas out the top of the carb at me!!!
supserdave
If it backfires out the carb your to far advanced.......Need to get the float problem fixed before you go on.
chargerman68
so wifey was playing in the car and pressed a switch and now the ignition works...no more remote start!!!   LOL
chargerman68
float fixed now it  still catches fire.....
supserdave
Timing is advanced to much......
chargerman68
off the dist...turn towards the driver or away
chargerman68
i have tried every which on the dist....still nothing :brickwall:
General_01
Turn the dist. counter-clockwise to retard and colckwise to advance. Also, check your idle mixture screws if you have fuel dumping out of the carb yet. Turn them all the way in. Back them out 1 and 1/2 turns for a base. That should be close. Count the turns as you screw them in. If they are backed out less then that, stay with that. The good news is that if you are getting fire, you are getting spark. Only a matter of time now. :icon_smile_big:
Get wifey to turn it over while you fiddle with the distributor if you can. :icon_smile_big:
1971 Dodge Charger Super Bee
496 stroker
4-speed
chargerman68
only have min turn on the dist due to vaccum advance and water pump housing hose..
Are you getting spark to the plugs ? My guess is that the plugs are fouled pretty bad with all the cranking you have done....the crankcase is probably full of fuel. Smell the dipstick and if it has a gasoline odor then change the oil and also get some fresh plugs in it....i like NGK xr-5's for iron head 440's.
You need to start from scratch, get the engine to TDC compression stroke and go through the firing rotation to double check everything. The rotor can be pointed to any tower on the cap as long as you follow the correct firing order going counter clockwise. I like to have the vacuum can pointed towards #1 cylinder as this will allow for movement fore/aft on the distributor when setting the timing.
First thing to do is verify spark....then swap in some fresh plugs and change the oil so you don't wash down the cylinder wallls with fuel and waste the rings.  :Twocents:
supserdave
I know this has been covered about 10 times, but where did you put the #1 spark plug wire on the distributor?  Did you find Top dead center and then take the dist. cap off and put it where the rotor is pointing?
Your close man!  :2thumbs:
General_01
Is your vac advance already hitting the heater hoses? If I look straight on at my dist from the passenger side, the canister nipple is at 1:00. I have a stock distributor. This gives me plenty of room between heater hoses and fuel line/valve cover for adjustment.
496 stroker
4-speed
chargerman68
firing order is fine here are some pics where i left off due to now again dead batt...
supserdave
Are you missing your distributor hold down?  It looks like the distributor is up out of the block to far??
chargerman68
i will check on that...
whats up with the carb fires???
cant get them to stop i wait at least ten fifthteen minutes before restart..
