Tail Light Bulbs for a '70
Started by GreenMachine, June 09, 2007, 06:02:01 PM
GreenMachine
What are the correct bulbs for the R/H and L/H inboard sockets for a '70. I have 1156 in there now and have tried a couple others but they are just as bright as the brake lights. So when I'm driving with lights on the 2 outboard lights are dim and the inboard lights are bright.
JimShine
You need a #97 for those inner bulbs.
GreenMachine
Dodge Don
Check this thread on that very topic. The factory bulb was 1095 which is no longer available. Use a 67 bulb to match the brightness of the other 1157 bulbs.
http://1970chargerregistry.com/70messageboard/viewtopic.php?t=34
Plumcrazy
Either a #67 or a #97 bulb will work fine.
JimShine
Yeah, I know from experience that #97 is a perfect match. You can try #67 too, if they are available locally.
