Flex plate
Started by Animal, May 19, 2007, 06:20:26 PM
Animal
The 440 ate & spat out the flex plate today , Was the starfish one , anyone else had this problem?
Thanks Adam.
moparguy01
never had that problem. but it sure looks pretty nasty.
Big Lebowski
  Ouch & ya I've heard of that happening before. Bummer dude
"Let me explain something to you, um i am not Mr. Lebowski, you're Mr. Lebowski. I'm the dude, so that's what you call me. That or his dudeness, or duder, or you know, el duderino if you're not into the whole brevity thing."
Adam, use the MP SFI plate with the MP bolt kit.....you won't break that one.  ;)
FYI : The MP sfi plate is designed for use with a TQ converter that has the 10in bolt pattern   :yesnod:
Animal
Thanks Guys.
Gotta have the box checked & stripped , cos the flex plate twisted the convertor in the pump.
Took the vertor out & found a line of brass all the way round the snout where it goes into the front pump , also brass fillings in the oil.
Adam.
Quote from: Animal on May 20, 2007, 01:41:46 PM
Thanks Guys.
Adam.
D@MN...sorry to hear that Adam  :P Time for some upgrades to the 727 while it's apart !  ;)
Animal
Always good to hear from you Ron. ;)
Only changed the box as an upgrade , harder shift , etc .......................................................
No nowt about boxes. ::)
the B&M full disc flex plate is a good option as well
Animal
