68 charger , yellow paint??
Started by dodgey68, May 15, 2007, 07:19:45 AM
dodgey68
hello i am restoring a 68 charger and i was after some info on the colour  yellow used on the 2nd gen models chargers, (68,69,70) , what are the names and codes?? , or if some one has pics of what colour on what cars, thank you
when all you own is a hammer, every job  resembles a nail.
dodgey68
and if some body has any info on what sort of fasteners you use to screw the candy cane shaped moulds, (doorbelts)?? to the car and if i can still buy them and have them sent to australia?? thank you
RECHRGD
The color code for '68 was SS-1.  Sunfire Yellow.  I like it! ;D ;D Bob
13.53 @ 105.32
dodgey68
and what was the colour and code on the 69 and 70 models , i think the 70 model is the brighter colour i am after?? thank you
chargerman68
mine is a 68 with top banana...not for 68 model years but still mopar
Chatt69chgr
69 was Y2 Sunfire Yellow.  I think the same color as the 68 SS-1Sunfire Yellow.  And Y2 Sunfire Yellow was available in 70.  But Y1 was also available in 70.  Depending on whether its a 70 Plymouth or a Dodge, the color is Lemon Twist or Top Bananna (not sure which was which).  But I think these are both Y1.  The Y1 is definitely a brighter Yellow.   But not as bright as the current Yellow on Rumblebees and Vipers.  The Y2 Sunfire yellow is a lot paler than the later yellows but tends to wash out in bright sunlight-----looks a lot better in the shade.  There have been pictures of 69 Chargers painted the Top Bananna color on EBAY before and they looked pretty good.  It won't be correct for a 69 but unless you are doing a numbers matching thing, who cares.  You need to paint it whatever you want it to be.  It's your car.
dodgey68
thank you it is a numbers matching but only a small block, just a charger, but i want to have it look original , lemon twist or top banana seems the way to go unless the the rumble bees have a nicer colour can any one tell me a little bout that and what that is called , thanks
