new engine questions
Started by charger01, May 09, 2007, 12:15:37 AM
charger01
My 440 has about an hour run time on it.  No real drive time.  Any suggestions what I shoud do to it next.  Change oil?  Should the plugs foul out quickly on a new engine in the process of adjusting carb and distributor?
Hemidog
charger01
I read that and is good info, but should the plugs foul out shortly after a break in?  also will a low battery contribute to a rough idling engine?  I have heard it will, but dont see how?
Big Lebowski
  If the alt. is working, the engine wouldn't care. I'd check for vacumn leaks. & Plugs get fouled on a cold engine with too much gas. Rev it up with new plugs.
"Let me explain something to you, um i am not Mr. Lebowski, you're Mr. Lebowski. I'm the dude, so that's what you call me. That or his dudeness, or duder, or you know, el duderino if you're not into the whole brevity thing."
staring it cold & running it for a short time can foul the plugs quickly
