Dwell
Started by Harlow, April 15, 2007, 07:23:05 PM
Harlow
I was readjusting my dwell today and I accidentally set it at about 22*, it made the engine smooth, it was the best I've ever seen it run. Is it possible that my setup may want a lower dwell? Are there any potential problems with running it that low? Could the coil overheat?
- Scott
oldkimmer
Less dwell = dist wear....with less dwell the coil does not need as much time to saturate, so it will not build up as much heat..........kim...
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
tecmopar
It should be around 30*, at 22 the coil won't overheat because the points are not closed for very long and the saturation is to short. What you actually did was increase the timing a bit by having the points open a little sooner then before. At idle it may seem fine but under a load you should start having misfire problems because the spark won't be fat enough to burn the fuel. Good luck.
supserdave
I would save 185 bucks and buy the electronic conversion kit.....My 2 cents, less messing around.
