73 Rallye side stripe
Started by 41husk, April 12, 2007, 02:45:06 PM
41husk
Can someone post the dimensions of the Rallye side stripe for a 73 Charger, how wide at front and back marker lights, and how wide at the middle ?  Thanks Allen
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
Here is the "templates" my graphic designer sent me before cut to aproove the decals. I didn't notice the charger and arrow cut outs were backwards on driver side door so that's something to fix.
You could try to enlarge this diagram to the real size to get the measurements and get real templates. Take the doors length and then enlarge the complete diagram untill the door section arrives to the right size, in tat way ALLL sections will get the real scale. Take on mind the door section is around 1 centimeter longer since stripe folds on both ends to clip on door ( almost 5 milimeter by side ).
I hope this helps
41husk
Thanks Natcho, Is there any way you could take some measurements and tell me What the withs are at the  smallest and largest points?
yes... I'll post tonight. I have NOS rallye stripes to take the exact mesurement
41husk
Thanks that would be great.  I will get it Monday then I am going out of town tonight and probably won't be back until late Sunday night.
dvnen
Hey Natcho - how are you going to the hood black out - do you have a template?
no, sorry... just side stripes because I have NOS used to scan and cut
Here the measurements I took. I tried to be the more exact posible since we use metric measurements and I'm giving you SAE measurements. It could be some milimeter mistake but will give you an idea.
The thin stripe is .25" wide.
Gap is around 1/8"
Take in mind I measured stripes not car so some areas flips in to body, so stripe is longer on those areas... maybe 4 or 5 milimeters
Another stuff is stripe is not horizontally symetric. Curves are bigger on some areas like the top curve on door section. That's why you would need to print this diagram to give you the idea. Maybe after you print, you could get the scale since you have the reference measurements between real measurements and draw and get the conversion rate.
I hope this helps
