test guages
Started by hcharger, April 11, 2007, 07:48:08 PM
hcharger
I have made up a  micky mouse  harness to  use  with an external 5 volt limiter  and a set of temp and gas gauges.   Does it matter what  post the wire from the 5 volt side goes to and the one from the sender.   It is a temp.  unit   but I do want a temp gauge    that works for now?????
Chatt69chgr
I don't know about testing your gauges but that's one heck of a garage and some real nice cars.  I'd give my eye tooth for a garage setup like that.  I am trying to do my work out of a single garage.
doesn't really matter. 3rd gen standart gauges/clusters and earliers clusters use one side to positive and the other side to negative just because printed circuit board design.
you can feed any stud with any power pole
hcharger
:drive:
Thanks  I figured that was the case   but just wanted to make sure before I blew any more gauges.
Thanks again
You can also use a 9 volts batt for a second or two, just for working test, not for graduation. I have done it.
