Viper T56 into a 68-70 B-body?
Started by Blakcharger440, April 05, 2007, 07:44:49 PM
Blakcharger440
What would it take to put a T56 trans from a 93 Viper into a 68-70 B-body?
Is there a mounting kit already out there or would this trans just not work.
Silver R/T
it would have to be all custom work, nobody has kits that you just install in b body
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Blakcharger440
Yep thats what I thought.  I could get a screaming deal on one.
471_Magnum
Biggest issue is the height of the T--56. Major surgery to the tunnel is required.
Silver R/T
it can be done though, remember the GTS Charger? Guy fitted whole viper drivetrain under a B body
2001 Ram 2500 CTD
WMIF
It does require trans tunnel modification.  The mount however requires very little mod to hold the t56.  The driveshaft also required only about an inch of tube cut off to be the correct length (coming from a 727).  I have long monkey arms (according to my wife) so I am comfortable with the placement of the shifter, but if you are not so tall you may want to make a different shifter to bring the handle back some.
69 Charger
440 in front of T56
Rolling_Thunder
My GF says I have the dreaded monkey arms as well...     oh well -  :2thumbs:
suntech
have seen a few cars that they putted T-56´s in, and they lift the trans tunnel 2-2,5 inches.
Is´nt there a kit to get, that moves shifter frther back???
superbirdtom
just wanted some advise. when I make my superbird roadracer clone someday, does tremec have a 5 speed and a 6 speed manual tranny??? do they make a pedal kit too for brake clutch setup???or should I go with a regular 70 b body 18 spline and an overdrive?? i run a 323 geared  8 3/4  rear on my present 4 speed bird  for the open road ,and it still needs an overdrive . I like to putt at 80 mph at about 1800 rpm.   thanks     Tom
