Dry sump oil pan
Started by Dodge69_440, March 23, 2007, 09:39:04 AM
Dodge69_440
Ok I know it's a stupid question but I'm always reading about dry sump oil pans in high performance cars.  Could someone explain what exactly a dry sump is and why it is better than a standard oiling system?
-thanks
69fourspd
"In a dry sump, the oil still falls to the base of the engine, but rather than being collected into an oil pan, it is pumped into another reservoir by one or more scavenger pumps, run by belts from the front or back of the crankshaft. Oil is then pumped from this reservoir to the bearings of the engine by the pressure pump. Typical dry sump systems have the pressure pump and scavenger pumps "stacked up", so that one pulley at the front of the system can run as many pumps as desired, just by adding another to the back of the stack.
A dry sump affords many advantages, namely increased oil capacity, decreased parasitic loss and a lower center of gravity for the engine. Because the reservoir is external, the oil pan can be much smaller in a dry sump system, allowing the engine to be placed lower in the vehicle; in addition, the external reservoir can be as large as desired, whereas a larger oil pan raises the engine even further. Increased oil capacity by using a larger external reservoir leads to cooler oil. Furthermore, dry sump designs are not susceptible to the oil starvation problems wet sump systems suffer from if the oil sloshes in the oil pan, temporarily uncovering the oil pump pickup tube. Having the pumps external to the engine allows them to be maintained or replaced more easily, as well."
Quote from: 69fourspd on March 23, 2007, 10:14:59 AM
That's a good writeup.  :2thumbs:
For most street/strip applications a wet sump works just fine. A windage tray and baffled oilpan will keep parasitic losses to a minimum and oil control in check. Personally, i would consider a dry sump only in a full race application where you're looking to extract every last horseower out of the combo.
Dodge69_440
Interesting, thanks a lot guys.
