De-code 440 engine
Started by Daytona Guy, March 18, 2007, 10:09:03 PM
Daytona Guy
I do not believe this is an original stamped codes, but it must mean something to what was done to this engine.
Block Cast -
3698830 440 7
Heads -
902
Pad -
E5 440 T 284 90
10.2.3
69CoronetRT
Got a pic you can post?
It's apears to be a 75 model year truck block
Daytona Guy
It appears to have six pack rods.
69CoronetRT
Quote from: Daytona Guy on March 18, 2007, 11:18:28 PM
I'm not much on 'internals' but I think all cars/trucks after 70 have the same rods or they could have been changed.
Got a pic of the pad?
Daytona Guy
Daytona Guy
Is there any way to decode these engines? Is there a good webpage?
69CoronetRT
Quote from: Daytona Guy on March 19, 2007, 12:21:20 AM
There could be but I'm not aware it. I do recall this for the mid 70's engines: if the "T" comes before the displacement, it means Trenton Engine plant and if it follows the displacement, it means truck. Typically, the "E" stamping of that era means cast crank. The 5 would be the model year. The 10.2 probably means assembled on Oct 2nd of 74. The .3 may mean thrid shift but I don't. I also don't know what the 28490 means. Typically, there is a sequence number stamped on the pad for cars but this seems awful high for a sequence number.
Guess I'm probably not much help on this one but here's a bump for some one who may know more...
mikepmcs
MOPARHOUND!
FWIW, of all the 440s I've looked at in my lifetime, that is the first time I have seen that style of font, and have never seen the  "." between what is presumably the date of assembly numbers.
At first I thought the 23490 might be some type of reference number stamped by a machine shop for future reference, but the "4" in it is the same as the "4"s in 440 on the pad.
What is the block's casting date?
1971 Charger R/T, 440 H.P., Auto, A/C Daily Driven (till gas went nuts).  NOW IN CARS FOR SALE SECTION: http://www.dodgecharger.com/forum/index.php/topic,48709.0.html
1969 Charger 318/Auto (latest addtion): http://www.dodgecharger.com/forum/index.php/topic,31948.0.html
*Speed costs money son, how fast do you want to go, and for how long?"
*"Build the biggest engine you can afford the first time."
*"We normally wouldn't use a 383 for this build, parts and labor for a 440 cost the same."
Daytona Guy
Did they stamp Truck and RV engine differently???  It does have 6 pack rods and the casting numbers on the heads are only for 1974 - 902's   Do 902's heads have hardened seats? I will check the casting date...  10 * 73 Casting date.
