360 headers
Started by 74340charger, March 17, 2007, 07:44:31 PM
74340charger
I have heard lots of good things about the headman headers, but I would be saving money by going with the summit headers. do any of you know what name brand the summit ones are? and what size should I get? Also do I need to get the smaller starter?
austinpalibroda
i'm not sure about headmen and summit, but i believe mine are hooker headers on my 360, i would think most are made for your regular starter, mine is. its a pain to change the starter but it could be worse i guess!
Canadian Mopar Boy.
LargerCharger383
I'm not sure of the manufacturer, but I've heard good things about summit headers.  And idk about yours, but i have a 383, and when i put headers on next winter i already know i'll need a ministarter.
RogerDodger
I just put Hooker Headers on mine. The starter fits ok but I hope I never need to change it.
Plumcrazy
My last set of Hedman headers where still fine after 25 years.  I only put a new set on because I wanted a ceramic coated set.
74340charger
thanks a lot for the help
deathcharger71
i have some old rusted headers on mine, fit with stock starter but changing it was not fun. mini starter fit much easier. arnt a lot of the mini "performance" starters just the stock starter from a 90's durango?
virtually all small block headers go under the center steering link Except the TTI which fit better & do not limit ground clearance butthey are more $$
74340charger
I guess I'll have the mini one that went out last summer rebuilt first then
Reidar
When I changed my starter into a mini, i got a problem as the ministarter was a little "fatter" than the original. Shorter yes, but fatter.. (wider) So my headers wouldnt fit properly. Had to change back to the old one to avoid farting.. ;) Pardon my french as i am Norwegian and "under the influence"!  :cheers:
-68 charger with 383..
