OK '68 Hemi owner's...... duh, guess I need to add a pic......
Started by hemi68charger, March 12, 2007, 09:35:20 PM
hemi68charger
Just showing the quark of my car.. Seems my hemi-equipped '68 Charger R/T didn't have the heater hose support bracket. This is the original sheetmetal, yet no hole over the shock tower for the bracket..... One side of me wants to "Not" put it on, and the other side wants to for order and "correctness" of year........ If I don't, the hoses will just lay across the shock tower........ The hole you see is for the rear washer bottle attach point......
Houston Mopar Club Connection
dart3404
If it's the original metal and there is no hole, not putting one there would be correct for that car... :shruggy: imo
Someone was sleeping at the Assembly line the day your car was built.
ChargerSG
Looking for 383 Magnum #0B196875 and 0B115166
TruckDriver
I know my car is a '72 Troy, but my car is missing holes for stuff here and there too. Like I am missing a hole for the voltage regulator(only have 2 out of the 3 that were drilled out), and one hole of my heater hose braket was drilled out on the right inner fender well.
PETE
UFO
I`ll ask you a question, Any evidence of the hole being welded closed?
                                Original fender well or was it replaced at some point during the cars life?
If its the original pce.Then I would leave it as is.
hemi68charger
Quote from: UFO on March 13, 2007, 05:53:08 PM
Nope, I had the car dipped and everything but metal is there..... There is absolutely no evidence of a patch or inner fender panel replacement. It's the original as far I can see....
Charger-Bodie
Quote from: hemi68charger on March 13, 2007, 08:25:15 PM
ok im a little weak in hemi knoledge but i know that non hemi 68 b bodys did not use that bracket the heater hoses were attached to the valve cover
Hemidoug
Troy, I have some pictures of a 68 Hemi R/T engine compartment around here somewhere. I'll dig them out for you. That should answer your question hopefully.
71 R/T 440 6pak, 4spd Mr Norms GSD
gtx6970
print and keep the picture, and DO NOT install one.
IMO
UFO
Troy your car is not the only one like that.You spotted this before on one of the road tests I posted.
Leave it be and use the band to hold hoses together.
hemi68charger
Quote from: 1hot68 on March 13, 2007, 08:29:55 PM
You are correct, non-hemi big blocks used the hose clamp-2-valvecover for the heater hose routing... Hemi's were the first to utilize what would eventually become standard issue on '69 big block B's....
hemi68charger
Quote from: gtx6970 on March 13, 2007, 08:45:23 PM
IMO
Quote from: UFO on March 13, 2007, 08:56:17 PM
Yeah, ya guys are correct.......... Since I did find other '68's without it, I'll just strap the hose like the one in the '68 test issue......
hemi68charger
Quote from: Hemidoug on March 13, 2007, 08:43:17 PM
Thanks Doug........ I appreciate any pictures for clarification and documentation..........
Corellian Corvette
I don't think 68's BB cars used that clamp. I'm pretty sure they have a heater hose clamp that's attached to the valuve cover to keep heater hoses in-line.
Don't know about Hemis...
hemi68charger
Quote from: Corellian Corvette on March 14, 2007, 01:10:33 PM
That's what I stated...... I posted the picture for Doug so he could see the routing for the Hemi's........
Corellian Corvette
Quote from: hemi68charger on March 14, 2007, 01:23:55 PM
SORRY! Missed the text in between the pictures  :-[
hemi68charger
Quote from: Corellian Corvette on March 14, 2007, 03:00:58 PM
:thumbs:
