voltage readings
Started by hemi68charger, March 10, 2007, 01:47:40 PM
hemi68charger
Hey gang....
I just did the conversion from amp gauge to volt gauge on my '69 Charger.. I was curious. The voltage readings,,,,,, shoulld it increase with engine rpm and then level off? I know the voltage regulator is supposed to maintain a 12v supply, but with the OEM mechanical regulator, will the voltage increase and then level off once the V.R. does it's thing...
Thanks....
Houston Mopar Club Connection
71_deputy
depending on many things- but as an average- yes- at idle the alt is barely or not at all charging-thus voltage is around 12 volts- give or take.
when driving- rpm's go up- VR see's a load due to battery been drained a bit- so volts go up until VR is happy and will stay around 13.7-14 volts.
1971 Deputy Challenger 383 4bbl-- 1 of 2 made!!
1967 Charger 440/auto
1973 Road Runner 340/4 speed
2000 1500 Ram Van
bordin34
If your lights get brighter as the engine revvs higher does that mean the regulator is broken?
1967 Coronet Black 440 Auto
Mahwah,NJ
Quote from: bordin34 on March 11, 2007, 11:37:49 AM
or BATT DAMAGED, unable to get recharged.
-Low Iddle speed.
-Loosen wires on alt studs or bulkhead.
-Big alt pulley.
-Short on alt or one of its components
