Door hinge rebuild 69 B body
Started by bricklayer, March 06, 2007, 05:06:57 PM
bricklayer
The upper and lower pins how do they come out hammer/ press/ heat what is the best way?  I'm getting Yearone rebuild kit with the 4 pins an 8 bushings  thanks  tom
AKcharger
Hi Brick Layer!
On my '70 they were pressed in from the factory. I cut off the head of the pin (like a rivet head) and pounded it out, took a bit of work.
Good luck
