Horsepower Question?
Started by lukendan, March 05, 2007, 06:59:04 AM
lukendan
I know that a stock 68-70 440HP is rated at 375 bhp. Heres the dumb question of the day. If a person has a Fresh standard bore 1972 440(steel crank motor), 906 heads (w/mild port), a little better cam, Edelbrock Performer intake, Edelbrock 750 CFM Carb, and Stock HP exaust manafolds, what might a person see out of that? I understand its hard to guess at that, but...
Luke,
From what you're describing i'd say that combo would be in the 400-425hp range depending on how well the heads flow and what the cam profile looks like.
If the pistons are the original type the low compression (about 7.8) will be a limiting factor.
Challenger340
Quote from: John_Kunkel on March 05, 2007, 04:22:04 PM
John's right, you mean the "low-pop" slugs ?
Only wimps wear Bowties !
lukendan
yes there the org pistons..."about 7. will be a limiting factor"<---What does this mean? Thx in advance
Challenger340
It means the original '72 Pistons tend to limit, somewhat, the power production/output due to the relatively low compression as John stated.
That said, not trying to confuse the issue, as Ron(Firefighter3931) says, it can still make 400-420 hp with properly done & selected heads, and Camshaft. Certainly "no slouch" by any means.
You'll find some great resources on here to that end, for actual Parts selection and "do's & don't do's".
Quote from: Challenger340 on March 06, 2007, 01:43:23 AM
:iagree: The low compression 72 pistons will hurt power output. In my response i should have mentioned a piston upgrade should be considered to achieve those power levels. The speedpro 6-pack replacement slugs are forged and very durable........as well as being relatively in-expensive.
lukendan
OK. I dropped the cash for the 10:1 pistons. Now what range in bhp can I maybe see? Also, what would be better for street use, a Eledbrock Performer intake, or a Eledbrock Performer rpm intake? Thx...
The RPM manifold is a much better choice. As for HP....that will depend on the cylinder head flow and the rest of the build ; cam, headers, carburator etc....
