Dash Frame / Column Paint.
Started by Mopar Crazy, March 01, 2007, 10:28:06 PM
Mopar Crazy
I'm restoring my Steering Column and Dash Frame from my 68 Charger.
The color is Black. Can someone tell me what Color Code and where can I get the correct color and paint???
Also any prep tips would be greatly appreciated.
Do it Once and Do it Right !!!
ChargerSG
Im about to that myself but for a 69 Charger, so i like to know to :icon_smile_big:
Looking for 383 Magnum #0B196875 and 0B115166
Back N Black
It is Black Suede Textured Paint, you can't by it off the shelf in a spray can you have to order it and shoot it with a gun.I think Mopaints carry it.
UFO
I used SEM brand trim black.Available in spray bombs.If your going concours judging might not be good enough for the judges.Thats if they even notice.
v21hemicharger
I just did my dash.  Had it chemically dipped so bare metal.  I used organosol mixed from the paint store, don't know the PPG fromula but it's still available.  It is very textured.  The mix they had had some metallic in it, but in my application, I liked it.  Going on pepper grey charger.  If I were not going concourse, I would try using SEM texture spray then trim black.  Sorry no pics, but maybe next week.  Mike
Mopar Crazy
Wow, a lot of good ideas... Thanks for the help.
Pete
MadScientist
Good timing.  I just finished both of mine. I lightly sanded the dash frame (it was in good shape). Cleaned it with PRE from Eastwood.  Then used Rustoleum primer (black) 2 coats over everywhere to seal it in.  Then I came back with several coats of Totallyauto Satin Black.  The first few coats went on in a regular fashion then I went on to dust the front and top from about 2 ft away to create the "suede" look.  Did the same for the column, but with much less texture.  Warning though, the suede part of it uses up quite a bit of paint. I used 3-4 cans to finish the dash.  I am happy with the way it turned out.
MS
MadScientist
Heres the in-process pic of the dash
MS
Mopar Crazy
MS, Nice Job.... Looks great....
Thanks That helps a lot.. I was going to call Totally Auto for the paint. Barbara helped me out with other paints in the past.
They do know their colors...
Thanks for the pics...
Pete
Shakey
Quote from: MadScientist on March 06, 2007, 02:16:42 AM
MS
That dash looks awesome!   :thumbs:
You need to share more of your progress pics with us.
Well done.   :yesnod:
ChargerSG
K9COP
I'm a bit confused guys, the restoration guide says that the instrument panel is painted the same colour as the interior, with the exception of white. Does this mean that my dash top, which faces the windscreen, should be green to match the interior?
I'd rather push a Charger than drive a Mustang.. which is lucky..
My cars:
'69/70 Charger 440
'03 Range Rover
'05 Audi A8R
'93 Lotus Omega (SOLD)
'97 Jag U Are XK8 (For Sale)
'68 Charger 318 (for sale)
'74ish Charger 400Magnum (sold)
'89 Nissan Skyline GTR (sold)
'92 Jeep Cherokee 9" lift (sold)
95 Crown Victoria Police K9 unit work car! (in the great impound lot in the sky..)
MadScientist
Thanks for the comments!  I will post more pics as I move along. As far as the dash frame is concerned, from what Ive seen, you are correct (Cayman) it should be the same color.
MS
UFO
Yes its supposed to be with a green interior,but not the same shade.There are different shades for various items.Your dash pads will be one shade and the dash a slightly different shade.
UFO
second page
UFO
I should add the above lists are for 1968.
