73 &74 front fenders
Started by doitmopar, March 01, 2007, 12:15:43 PM
doitmopar
??? :oWill 73 & 74 front fenders interchange  as far as bolting up correctly and having the right lines? ???Thanks.
Charger1973
73 and 74 fenders are identical.
ALL 3rd gens fenders fit and matches with rest of body lines, but just 73/74 are identical
RogerDodger
Quote from: Nacho-RT74 on March 01, 2007, 12:44:40 PM
Would a 72 be identical to 73/74? I know the side marker lights would be different for 71.
Charger1973
Quote from: RogerDodger on March 01, 2007, 05:43:25 PM
No, the wheel opening is cut higher on 73/74 fenders.  Its not real noticable unless you see them side by side.  I have also heard there is one bolt hole that doesnt line up (not really a big deal even if its true), but I have never swapped the two to know that for sure.
doitmopar
:o I guess i have 72 left fender on a 74 because there is one upper  bolt hole that will not line up.I was hoping that was the case.Thanks Guys
the Valance front  splash shield and area where is bolted on underside fender is completelly different too between 71/72 and 73/74
