Lost power to tach, turn signals, oil press, water temp & fuel
Started by 440mag, February 27, 2007, 10:06:32 PM
440mag
Was dropping off my car tonight (72 Charger) to get a headliner installed and lost power to the tach, turn signals, oil press, water temp & fuel.  Did not have time to trouble shoot it with him meeting me after hours and my wife waiting to give me a ride home.  Has to be something simple since the car just came from getting painted and it all work good before.  All new Year One wiring in 1999.
Any ideas on what you would look at first for those of you that have the wiring schematic memorized?
Thanks Paul
440mag
do you have Radio, A/C or heater, back up lamps  ?.
Voltage limiter what feeds the cluster guages is feeded directly by black wire of ignition switch.
That same black wire is what it feeds the accesories side of fuse box, where the tach and turning signal flasher take the power
check for power on accesories side of fuse box on accesories position.
If not power then probably you have accesories source death. Probably damaged ignition switch, black wire or terminal/plug down the column loosen or dirty.
440mag
Thanks I'll check it as you recommended.  Just got the car home and it work all the way and I did not touch it.  But Ill dig in and find caused it, I can't stand things that aren't right.
do you have Radio, A/C or heater, back up lamps  ? Did not check or notice the back-up lamps or AC light.   Do not have power to the stock radio, it is there just for looks.
440mag
not A/C light... A/C ITSELF: blower and compressor clutch
