Rummy rules
Started by d72hemi, February 13, 2007, 04:30:41 PM
d72hemi
I know this is way off topic, and that I should be able just look it up on the web myself, but the only computer system I can use at this time, blocks many site categories, including "Games". Would one of you please post or PM me the rules for the card game rummy, I spent the last 2 hours trying to find a site not blocked. I know I sound stupid, but a coworker's and my memory do not match, so I need the rules to "through it in his face".
Charger_Fan
I swiped these from this site, in case you can view that one; http://www.pagat.com/rummy/rummy.html :)
Types of Rummy
Rummy games first appeared in the early twentieth century, and are probably derived from the Mexican game Conquian. This page describes basic rummy, also known in the card game literature as Straight Rummy. For other types of rummy, and related games, see the rummy index page. Note that many people use the name Rummy to refer to the game called 500 Rum on this site, in which more than one card can be taken from the discard pile, and points are scored for cards melded. For details of this game, see the 500 Rum page.
Basic Rummy
The game is best played with two to four players, but up to six can take part. Either a fixed number of deals are played, or the game is played to a target score. The number of deals or the target score needs to be agreed before beginning to play.
The Deck
One standard deck of 52 cards is used. Cards in each suit rank, from low to high:
Ace 2 3 4 5 6 7 8 9 10 Jack Queen King
The Deal
The first dealer is chosen randomly, and the turn to deal alternates if there are two players, and rotates clockwise if there are more than two. In a two player game, each player is dealt a hand of ten cards. Seven cards each are dealt if there are three or four players, and when five or six play each player gets six cards. The cards are dealt one at a time, and after the deal, the next card is placed face up on the table to start the discard pile, and the remainder of the deck is placed face down beside it to form the stock. The players look at and sort their cards.
Object of the Game
The object of the game is to dispose of all the cards in your hand. There are three ways to get rid of cards: melding, laying off, and discarding.
Melding is taking a combination of cards from your hand, and placing it face up in front of you on the table, where it stays. There are two kinds of combination which can be melded: sequences (also known as runs) and groups (also known as sets or books).
a sequence or run consists of three or more cards of the same suit in consecutive order, such as 4, 5, 6 or 8, 9, 10, J.
a group, set or book is three or four cards of the same rank, such as 7, 7, 7.
Laying off is adding a card or cards from your hand to a meld already on the table. The cards added to a meld must make another valid meld. For example to the 4, 5, 6 you could add the 3 or the 7. You are not permitted to rearrange the melds in the process. For example, 2, 2, 2, 2 and 3, 4, 5 have been melded, you are not permitted to move the 2 from the group to the sequence, so as to lay off the A.
Discarding is playing a card from your hand on top of the discard pile. You get rid of one card this way at the end of each turn.
Play
If there are two players, they take alternate turns starting with the non dealer. If there are more than two players, they take turns in clockwise rotation, beginning with the player to dealer's left.
Each turn consists of the following parts:
The Draw. You must begin by taking one card from either the top of the Stock pile or the top card on the discard pile, and adding it to your hand. The discard pile is face up, so you can see in advance what you are getting. The stock is face down, so if you choose to draw from the stock you do not see the card until after you have committed yourself to take it. If you draw from the stock, you add the card to your hand without showing it to the other players.
Melding. If you have a valid group or sequence in your hand, you may lay one such combination face up on the table in front of you. You cannot meld more than one combination in a turn (but see House Rules). Melding is optional; you are not obliged to meld just because you can.
Laying off. This is also optional. If you wish, you may add cards to groups or sequences previously melded by yourself or others. There is no limit to the number of cards a player may lay off in one turn.
The Discard At the end of your turn, one card must be discarded from your hand and placed on top of the discard pile face up. If you began your turn by picking up the top card of the discard pile you are not allowed to end that turn by discarding the same card, leaving the pile unchanged - you must discard a different card. You may however pick up the discard on one turn and discard that same card at a later turn. If you draw a card from the stock, it can be discarded on the same turn if you wish.
If the stock pile has run out and the next player does not want to take the discard, the discard pile is turned over, without shuffling, to form a new stock, and play continues - but see the variations section for a discussion of alternatives and problems that can arise.
A player wins an individual hand by either melding, laying off, or discarding all of his or her cards. Getting rid of your last card in one of these ways is called going out. As soon as someone goes out, play ceases. There can be no further melding or laying off, even if the other players have valid combinations in their hands.
Scoring
When a player goes out, the other players add up the value of all the cards still remaining in their hands, as follows:
Charger_Fan
The rest here (9,000 word limit on posts)
Face cards (K,Q,J) are worth 10 points each
Aces are worth 1 point each
Number Cards are worth their face value - for example a six is worth 6 points, a four is 4 points, and so on.
The total value of all the cards in the hands of the other players is added to the winner's cumulative score.
The game continues with further deals until a player reaches the points target that was decided before the game began, or until the agreed number of deals has been played.
Optional House Rules.
These optional rules should be discussed and decided by the players before the beginning of the first deal.
Multiple Melds
Some people play that you can lay down as many melds as you desire in each turn.
Most people allow a player who has not previously melded or laid off any cards to earn a special bonus if they can go out in a single turn by melding or laying off their entire hand. This is called going rummy, and the score for the hand is doubled, or in some versions the winner gets a bonus of 10 points.
Laying off
Some play that you may not lay off any cards on other players' melds until you have laid down at least one meld of your own.
Ace High or Low
In the standard game, aces are low. A-2-3 is a valid run but Q-K-A is not. However, some play that aces can be counted as high or low, so that Q-K-A is also a valid run. When playing with this rule, aces are given the higher value of 15 points instead of 1 point, refecting their greater usefulness.
A few players go further and allow "round the corner" runs with an ace in the middle (K-A-2), but this is unusual.
Last discard
Some people play that in order to go out, you must end your turn by discarding your last card. You are not allowed to meld all your cards, leaving nothing to discard.
End of the Stock
Some play that when the stock has run out and the next player does not want the discard, the discard pile is shuffled before resuing it as a stock. This is the version now given in most books. If there is no shuffle, players who can memorise the order of cards in the discard pile will clearly have an advantage.
It is just about possible, though very unlikely, that a repetitive situation could occur where each player is holding on to cards wanted by the others. Each player draws from the stock and discards the card they just drew. In this case, recycling the discard pile as a new stock, whether shuffled or not, will not help. If the players are stubborn, the game could be endless. To avoid this, it may be a good idea to limit the number of times that the discard pile can be reused as a new stock. I suggest that after the stock becomes exhausted for the third time, the play should end if the next player does not want to take the discard. Alternatively, you could agree that the discard pile gets reused only once and the play ends when the stock is used up for the second time.
In the version known as Block Rummy, the discard pile is not reused at all. If the stock has run out and the next player does not want to take the discard, the game ends at that point. Everyone scores the value of the cards remaining in their hands.
If the game ends without anyone going out, all players count the value of the cards remaining in their hands. The winner is the player with least points, and scores the sum of the differences between this and the points in each other player's hand. Example: A has 6; B has 15; C has 7; D has 21. A is the winner and scores 25 = (9 + 1 + 15). If two or more players tie for lowest, they share the winnings equally.
Players are allowed, at their turn, to count the number of cards remaining in the face down stock if they wish. As a courtesy (to save others having to count as well), a player who counts the stock should correctly announce to the other players how many stock cards remain.
Scoring
Some play that instead of the winner scoring points, each of the losers score penalty points according to the cards left in their hand. If the game ends without a winner then everyone scores their cards as penalty points. When someone reaches 100 or more, the player with the lowest score wins.
Some play that each loser pays the winner according to the number of points in their hand (or the difference between their score and the winner's score if no one went out). This method is appropriate when playing for money. The session would last for a set number of hands rather than be played to a target score.
Charger-Bodie
 rummy is fun but my mom cheats
d72hemi
Thank you Charger Fan! I was right, he had the rules remembered wrong! but then again the rules that we are playing by do not to close to Rummy rules you posted. LOL.  ??? What we got going on is similar. Maybe we are playing gin rummy? we have similar lay down rules i.e. 2 3 4 of hearts, or 8 8 8. Although the we are counting the points as 5 points a card, 10,J,Q,K being 10 points, and A being 5 or 15 i.e. A 2 3, A being 5 points, or QKA or AAA  A being 15 points each. Playing to 500 points. Also if there are points in the discard pile i.e. someone laid down three 8s and the forth is in the discard pile, one could call "rummy" and play that card against the others. I am now wondering if we are not really playing an established game, but maybe a combonation of rules from different games, because I seem to recognise the rules, but I pick up a deck of cards maybe once a year?
As for the link I could not access it due to the filtering software (its too good).
I hope you and GTX did not have any friends or family in the mall, when all hell broke loose.
1hot68,
How does your mom cheat??? I lost 7 of the nine games played. Luckily we only play to find out who is paying for coffee at the end of the week. This week I am loosing 1 to 2.  :devil:
Ian
PS My coworkers love this site..... OK, it my have a thing to do with the "Chicks on Chargers" postings. LOL.
