air line
Started by Silver R/T, February 09, 2007, 04:05:43 PM
Silver R/T
I would like to know how you guys set up your air compressor/ air line. How many ft of line you got before its plumbed into air dryer/filter. What diameter did you go with?
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
mikepmcs
Silver R/T
2001 Ram 2500 CTD
mikepmcs
Silver, why?  You could get some other good information about what other members are using as well. :thumbs:
v/r
Mike
Chatt69chgr
Some of the best info I have found on this is an outfit called TP Tools.  Look them up under tptools.com.  Then look at their tech tips and then air line hookup.  It shows a diagram of how to do your air system and gives reasons why.  And they sell abrasive blasting guns.  The cabinet you get at Harbor freight is OK for the price.  You need to do some modifications to it.  Hang a flexible plastic sheet on the back to keep from blasting the back wall.  Use j-hooks.  The sheet is the clear vinyl floor runner you can get at Home Depot.  They have a gigantic roll.  You roll off what length you need.  Sold by the foot.  Then use brass grommet kit from about anywhere to keep plastic from tearing thru the j-hooks.  Also need some tearoff plastic for the window or it will get fogged up.  You will need to put a vacuum cleaner on the exhaust to pull out the dust clouds or you won't be able to see what you are doing.  Vacuum cleaner won't last forever but the plastic hang-up shop vacs are dirt cheap now.  Get a gun from TP.  They have the foot switch to control the air too.  Harbor Freight has a couple of kinds of blasting media.  If you need to change from one type to another, you can store it in plastic buckets.  I have some that cat litter came in that my daughter saves for me for this purpose.  I realize I have diverged away from the basic topic of air lines but once I got started, I couldn't stop.  Ignore this other info if you don't need it.
Silver R/T
Quote from: Chatt69chgr on February 09, 2007, 08:01:49 PM
that's exactly how our sandblaster is set up at my work. Very good setup. Too bad you cant sandblast big parts
2001 Ram 2500 CTD
Chatt69chgr
Cabinet size will obviously hinder blasting big parts.  One possible solution would be to move outside and do it on a big sheet of plastic so you could reclaim the blasting media.  If the neighbors will allow it.  And there is also the idea of the pressure blaster.  A lot faster.  Also needs to be outside.  But you really need a lot of air.  Probably minimum is 2 stage/7.5 hp 80 gallon tank setup.
