The 440 is 95% done
Started by BlueSS454, January 01, 2007, 10:28:39 PM
BlueSS454
Since I had some time this weekend, I buttoned up the bottom end of the 440 with the new oil pan and pickup.  I got the intake, valve covers, motor mounts, PS pump, alternator brackets, and some other misc items on.  Now I just need a new distributor kit, wires, and the various sending units and it's finished!  Here are some pics to enjoy.
Tom Rightler
4cruzin
WOW thats looking sweet!  Just need to touch up that distributer alittle and you'll be all yet!  Nice job!   :icon_smile_big:
Tomorrow is promised to NOBODY . . . .
Judhudson
That baby is sharp! Did you do all the work yourself?
BlueSS454
Thanks guys.  Actually, the engine was already rebuilt when I bought the car 5 years ago.  All I did was check things out to make sure everything was all in order.  I completly cleaned and repainted the block and heads.  Took the timing chain cover off, sandblasted it and painted it, installed a new 6 qt oil pan from Mopar Performance, sandblasted and clear coated the intake, sandblasted and repainted all the pulleys and brackets.  I cleaned and hand sanded the PS pump and resovoir and reshot it with some Eastwood underhood black.  I still need to finish the PS pulley, find the AC Compressor brackets (I don't have any), make up a fuel line, get the Electronic Ignition Kit conversion from Mopar Performance and get some plug wires.  I'll probably be dropping it back in the car sometime in late Feb/early March after it's painted.
Tom Rightler
Silver R/T
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
blue69
Looks good. I don't know if that lower alternator bracket will work with a/c. The top one is correct. BPE is the only place I know that sells a reproduction one http://www.bouchillonperformance.com/BPE5253.asp. They are expensive and you might be able to find a original set for cheaper. You also need a idler pulley for the a/c. I'm not sure if anyone makes a reproduction bracket and spacer. The spacer is hard to find and looks like a lower case h.
BlueSS454
I've been having a problem trying to find all the correct brackets and whatnot.  I located today a 73 New Yorker that has a Big Block with A/C and I was going to go back and take the whole A/C system off it.  The guy at the junkyard said I could have everything for $200.  I noticed 2 differences with the C body setup though.  1, the obvious is the suction and discharge hoses are routed differently.  2, the C body had a Federal style power steering pump on it and that has completly different brackets.  That made 1 belt run around the crank, water pump, and PS pump leaving the idler pulley out of the picture.  I'm trying to figure out what to do here about it.
Tom Rightler
